Machine Vision
CCTV IP camera interface
Hi everybody
 I have a Dahua bullet CCTV IP camera (there are BNC, Ethernet port).
How can i grab Image/Video from camera in Labview ? (CCTV IP camera Labview interface)
it didn't appear device on NI MAX
Could anyone help me involve this problem please
Message 1 of 10
(3,615 Views)
Do you have VAS (Vision Acquisition Software)?
https://www.ni.com/en-us/support/downloads/drivers/download.vision-acquisition-software.html#345649
George Zou
Message 2 of 10
(3,572 Views)
Yes, i do   I've already setup AVS, NI MAX, Vision assistance but it doesn't appear the camera
Message 3 of 10
(3,560 Views)
So you have IMAQdx?
George Zou
Message 4 of 10
(3,555 Views)
Yes i already setup IMAQdx
 this is the camera that i use
https://www.satsdigital.com/download/IPC-SF120_Datasheet.pdf
Message 5 of 10
(3,553 Views)
It seems this camera doesn't support directX.  So not supported by IMAQdx.
Do you have SDK for this camera?  If you do, you can use CLFN to call dll.
George Zou
Message 6 of 10
(3,547 Views)
So this kind of camera don't be able to use with Labview interface ?
Message 7 of 10
(3,544 Views)
Yes, you can use it in LabVIEW
IF YOU HAVE the SDK from the manufacture.
George Zou
Message 8 of 10
(3,541 Views)
Yes there is SDK from the manufacture
but how could i connect it ?
  Do you have some example code with using SDK ip camera labview interface?
 Thank you so much
Message 9 of 10
(3,411 Views)
Using External Code in LabVIEW:
https://www.ni.com/pdf/manuals/370109a.pdf
George Zou
Message 10 of 10
(3,400 Views)
