Machine Vision
C-mount macro and prime lenses for 1" CCD?
Anyone have good reccommendations for following lenses all C-mount, 1" sensor, NO FISHEYE, NO CHROMATIC DISTORTIONS must cover the entire CCD, 16mm diagonal 14mm x 8mm, offset from array to lens mount is 17.5mm 1. prime 10mm 2. macro 12-28mm 3. macro 35-100mm 4. macaro 80-150mm 5. prime 200mm
(3,788 Views)
Unfortunately, because you are asking about 3rd party lenses, I can't offer you much advice as I am not familiar with those lenses.  If you have some questions about setting up your Vision application, I will do my best to help.
I suggest that you contact Edmund Optics or Graftek Imaging -- both NI Alliance members.  They should be able to better advise you about which lens to use.
Rishi L
(3,766 Views)
neither has a section of lens for which i'm looking.
hopefully others will have used lenses which they can reccommend.
so far this forum is not a lot of use, it is mainly for beginners debugging code.
(3,755 Views)
why haven't you commented on my Basler 1900 thread?
NI is supposed to support Basler products. I see no GiGe drivers in NI Vision or Vision Acquisition.
I see no solutions for storage of raw 12-bit linear data at 24fps. I see codec support either.
(3,754 Views)
I'm sorry we can't help you further with your issue regarding those specific lenses.
Unfortunately NI is not a lens manufacturer, so I am unable to provide you specific commentary on the lenses you were curious about; besides the few Computar lens that we resell.
With regards to the Basler 1900 Camera, we do resell and support a few cameras by Basler, but the 1900 is not one of them.  If you need a GigE camera driver, you can purchase our Vision Acquisition Software, which contains the IMAQdx driver, which supports GigE cameras.
Rishi L
(3,743 Views)
