Machine Vision
C Code for Bit Shifting 10 & 12-bit images for 8-bit display
Can someone please point me to some C code that I can use for bit shifting 10 & 12-bit images to convert them to 8-bit for display?
Thanks for your help.
(4,128 Views)
If you have vision acquisition software there should bean option to include Visual C examples during the installation.  You can check/repair the installation to include these examples.  In MAX expand "Devices and Interfaces" then right-click on software and select  "Change/Remove Software"  this will bring up the Windows Modify/Repair/Remove wizard for National Instruments software.  Select NI-IMAQ then click modify, you will need the VAS disk.  Then select to include examples.
After the examples are installed you can go to Start >> All Programs >> National Instruments >> Vision >> Text-Based Examples.  I would open the read and and define the image type as U16.  There will be unused bits but the IMAQ display will scale it to 8-bit resolution.
Isaac S.
(4,108 Views)
