08-09-2019 08:49 AM
I can grab video from the camera with the Basler pylon software. It is also recognized in NI-MAX but it tells me to switch to IMAQ Vision driver to use it. When I do that it vanishes from the list in NI MAX. I have to reinstall the Basler driver over pylon Software to make it visible again. Are there additional driver I have to install? I am running Windows 10, Labview 17.0.0, IMAQdx 17.1.0, NI MAX 18.5.0f0.
Best Regards
Solved! Go to Solution.
08-09-2019 10:44 AM
Can you show screenshots of device manager after you've switched drivers? Can you find the device there?
08-13-2019 03:24 AM
I attached the screenshot. When i disconnect the camera the USB3 Vision device vanishes from device manager, therefore I assume it is the camera The device status states that the digital signature of the driver cannot be checked. Possibly a file might be damaged etc (code 52). Unfortunately I am running the german version of windows therefore I can't give you full english equivalent.
08-13-2019 11:26 AM
Thanks for the screenshot -- that explains it. Unfortunately the combination of IMAQdx 17.1 and Windows 10 results in this issue -- sorry you came across it! Here's a KB that describes it and makes recommendations: https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z000000P9IFSA0&l=en-US
Ideally just upgrade to IMAQdx 17.5 (or later) and you should be all set.
Hope this helps,
Katie
08-19-2019 08:09 AM - edited 08-19-2019 08:10 AM
Updating the package resolved the issue. Thank you very much!
