Machine Vision
BRIGHTEN IMAGE
hello!
is there any vi in NI vision palette that can bright an image.
or any other method to brighten an image?
kindly tell me asap... 😞
Message 1 of 8
(4,763 Views)
take a look at the following example:
http://zone.ni.com/devzone/cda/epd/p/id/5639
https://decibel.ni.com/content/blogs/kl3m3n
"Kudos: Users may give one another Kudos on the forums for posts that they found particularly helpful or insightful."
Message 2 of 8
(4,741 Views)
hi Klemen
thnx for reply. i used vision assistant vi. but problem is taht,no matter what image i attach at input terminal it shows the result of image that i have taken as a control in the vi. is there any method that use same vi to get results of different input images?
thnx
Message 3 of 8
(4,709 Views)
Please see the attached code.
Message 4 of 8
(4,698 Views)
Thnx once again sir 🙂
Message 5 of 8
(4,677 Views)
hi Klemen!
is it not possible for u32 bit images? instead of u8?
Fairy
Message 6 of 8
(4,674 Views)
yes, it is possible. U32 image has 3 color planes + alpha channel (3*U8 + 1*U8 = U32). You just need to extract the correct plane (in the appropriate color space) and you are performing your operation on U8 again
See the attached code.
Message 7 of 8
(4,667 Views)
Alternatively, you could also use "IMAQ ColorBCGLookup VI", where the lookup table is applied to red,green and blue plane seperately.
Message 8 of 8
(4,639 Views)
