Machine Vision
AxCWIMAQViewer.ControlImage question
I am trying to use the AxCWIMAQViewer.ControlImage() method (Vision 8.6, C#) to extract a currently displayed image for saving to a file. The image after extraction has a very large pixel size (image.Width, image.Height) which is greater than the original data or the screen size. My first question is where is this resolution coming from? The second thing I am seeing is edges of different shades of gray surrounding the image (frame borders?). I would like to extract only the data and not the background around the data or the borders of the control. I have been trying to extract the rectangular region of the data by finding the transition of the image and the actual data, but I am finding multiple shades of grays and blacks and they are not the same on any of the sides. Once you get the image is there a way to then extract only the actual data and not the blackground, borders and/or what ever else is in the image surrounding the data?
John A. Lively
NDE Engineer
Pratt & Whitney
(3,270 Views)
Hello Pratt,
Do you want to save the image displayed on IMAQ Viewer Control?
If so, you may see these threads:
Saving Picture wih Overlays in C#
Saving an imaq image to disk using CWIMAQVision
If not, please specify more and post the image you complain about.
Have a lovely day
Message Edited by VBCoder on 08-30-2009 11:34 AM
Waleed El-Badry MSc.,MCPD, ISTQB Certified Tester
Assistant Lecturer
Mechatronics Department
Faculty of Engineering
Misr University for Science & Technology
View Waleed El-Badry's profile on LinkedIn
(3,252 Views)
