Machine Vision
AutoBThreshold deletes Vision Info from template
Hi at all, wondering why an application which worked with LV/Vision 8.21 did not work with LV/Vision 8.51/8.5 I found out, that the function IMAQ AutoBThreshold deletes the Vision Info from a learned template. I think this is a bug, because the function only analyzes an image and returns a threshold level and a lokup table. So I would expect, that the image is not modified at all. I attached a small example which shows the issue. If you run it with 8.2.1 there is still the Vision Info left, under 8.5.1 it is removed. I do not need a workaround - I just want to report the bug. Greetings, Stefan
(2,879 Views)
Hey nice finding!!!
(2,853 Views)
