Machine Vision
Asynchronous reset mode using VC++,How?
I would like to develop asynchronous reset mode with Imaq 1409 and Jai CV-M10 under VC++ enviroment.
It is lack of explanations of how to use functions and parameters under c++,I don't even understand what's the constant means.
Can somebody tell me how to solve that?
tks
(3,005 Views)
tks,
After reading over your question I am not positive that I understand the specific question you are asking. It sounds like you are trying to setup your JAI CV-M10 camera in asynchronous reset mode. If this is the case, there are detailed instructions for configuring the camera in this document:
Using the JAI CV-M10 Camera in Asynchronous Reset Mode with the IMAQ 1409
That document will walk you through setting up the camera so that it can acquire in asynchronous reset mode, and should answer the majority of your questions about the process of setting up the camera in this mode.
At the end of the above document, it also walks you through a LabVIEW pr
ogram that generates an output pulse to trigger the camera in asynchronous reset mode. It sounds as though you would prefer to program your application in Visual C++. Even if this is the case, I would still look over the notes about the LabVIEW application, as they provide a good base from which to start your C++ application. The general format of this application would be: Initialize, Configure/Create Buffers, Start Acquistion, Extract/Examine Buffers, Stop Acquisition, Destroy Buffers. If you wanted to create your own pulses as part of the program, that would have to be added in as well.
Overall, I believe that the document that I linked above should get you going in the right direction. If you have additional questions after looking over that material, please post again, and ask as detailed a question as possible, so that this forum can help you to answer your question.
Jed R.
(3,005 Views)
