Machine Vision
Aquire webcam frames
...and the size problem is back, because the codec change changed also the frames per sec. (now he freezed every 30 frames, in other words, 2 frames per second) also the quality is way worse then the big .avi's, anyone a better idea?
edit: So it is important that the resolution stays at 960x720 and 30 frames/second (because of the accuracy of the frame by push the trigger button) (later I want to make a graph with a timescale and frames and triggermoment
Message 11 of 14
(3,486 Views)
the resolution may be a little less (pe 800x600)
Message 12 of 14
(3,470 Views)
Btw, I am able to acces cam in MAX
Message 13 of 14
(3,465 Views)
Message 14 of 14
(3,464 Views)
