Machine Vision
About NI Vision Assistant Tutorial
In the NI Vision Assistant Tutorial       the  Figure 2-5    acquire image(USB)   is  Grey.  why?
before install    imaq_usb_installer_setup.exe     Click the acquire image(USB)       Pop-up a dialog.
after  install    imaq_usb_installer_setup.exe   The acquire image(USB) is also  Grey,and click it  no response.
why?
why?
why?
why?
(3,964 Views)
I am not getting your point.Can you put it in another way?
(3,813 Views)
Hansen,
      If you want perform geometric pattern match for instance, image must by grayscale. you can either capture the image in graylevel format or acquire RGB image, then perform color plane extraction or any other method to convert it to gra level. If your algorithm work on coloured image, then just capture the image in full colour and you will be able to use colour processing methods in IMAQ vision Assistant.
Waleed El-Badry MSc.,MCPD, ISTQB Certified Tester
Assistant Lecturer
Mechatronics Department
Faculty of Engineering
Misr University for Science & Technology
View Waleed El-Badry's profile on LinkedIn
(3,808 Views)
