Machine Vision
3-Chip Color CCD - suitable frame grabber card
Dear Sir
we want purchase Jai 3-Chip CCD (color) from the models indicated below
CV-M90 (PAL)
CV-M91 (PAL)
OR CV-M9 CL
CV-M9GE (THIS ONE DOES NOT NEED A FRAME GRABBER CARD
WE NEED NI ADVISE WHICH FRAME GRABBER CARD ALONG WITH THE ACCESSORIES WE NEED IF WE BUY ONE OF THEM AS WE ARE CURRENTLY WORKING WITH LABVIEW 8.5 FOR INTERFACING THE DEVELOPED PROGRAMS.
KINDLY ADVISE THE SUITABLE CARD IF WE GO FOR ANALOG 3-CHIP CCD M90 OR M91.
MOHAN
(3,333 Views)
Dear mohannandigana,
Since it looks like both the CV-M90 and CV-M91 both output analog video in the PAL format, you can use one of our analog framegrabber cards that supports this format. You can choose between the 1405 and the 1411. You will also need the appropriate cables (BNC) to connect your camera video signal and/or trigger signal to the framegrabber.
The NI-IMAQ driver is used with these framegrabbers, and can be downloaded from our website as part of the Vision Acquisition Software.
Best Regards,
Nate
(3,310 Views)
