Machine Vision
24 GB of RAM but still "not enough memory to complete this operation"
Hello Everyone
I have an application running on Windows 7, 24 GB RAM, 64 bit computer. I am using Labview 2011, 32 bit and trying to acquire images from a camera. Although I have 24 GB of RAM but while acquiring, the physical memory usage goes upto 8 GB and after that I receive the "not enough memory to complete this operation" message. Any help on how it can be corrected.
Chauhan
(4,146 Views)
You will need to switch to LabVIEW 2011 64 bit to take full advantage of the 24 GB of RAM installed in your machine.  LabVIEW 2011 64 bit can be downloaded from ni.com and installed using the same serial number.
(4,139 Views)
We are developing an application with Labview 2011, 32 bit, to accuire images at 100fps. Aplication will run in another computer with more than 8GB of RAM (probably 32GB), without having Labview installed, it will only run the exe file. So our questions are:
we will found also the 8GB limitation?
If so, the solution could be to buil the application with LV 2011 64bit?
aditional information will be apreciated.
Marc.
(4,067 Views)
Yes.  You should download and install LabVIEW 2011 64 bit to take full advantage of any memory over 4 GB.  There is a seperate LabVIEW 2011 64 bit run time engine you'll need for your second machine to run your LabVIEW 2011 64 bit exe file.  You can find the 64 bit versions of the run time engine on ni.com.
(4,058 Views)
