Machine Vision
1409 image not in colour
hi
im grabbing a colour image from a pc to tv box that has an RGB output.
these are connected to video 1,2 and 3 on a 6822 and then into my 1409.
these inputs are set to RS170 (as stated in the literature)
however the image i grab in the imax application are grayscale.
shouldnt this be in monochrome colour ie red , green or blue?
many thanks
(3,433 Views)
Are you set up for StillColor RGB mode?
See various references here:
http://search.ni.com/nisearch/main/p?q=stillcolor
(3,429 Views)
ive checked the operating mode tab and there doesnt appear a stillcolour mode section under this or any tab.....
(3,427 Views)
Instead of using RS-170 try using NTSC or PAL 🙂 I used a 1408 and it works in colors selecting NTSC and stillcolor mode "composite".
When i select rs-170 the image is monocrome, when I select NTSC is Colored. Maybe this information helps 😛 bye
Mensaje editado por Paul_m6
Paul
Mechatronic engineer
Lima-Perú
(3,364 Views)
