Machine Vision
如何把System.Drawing.Bitmap 转VisionImage 格式 函数包只对VisionImage
我从相机采集到的图片送到NI图像函数中转换不了 imageViewer1.Image.ReadFile() 这函数只能从磁盘路径度 ,想请教如何把 内存中的图转为VisionImage格式,或者有其他方法,请赐教。谢谢!
(4,664 Views)
Try posting in english here
Translation
I collected pictures from a camera sent to the NI image functions in the conversion can not be imageViewer1.Image.ReadFile () This function is only available from the disk path of degrees, would like to ask how the memory map to VisionImage format, or have other methods, please enlighten. Thanks!
(4,662 Views)
(4,661 Views)
Have you got any solution for this problem?
Please update if any information available.
(4,104 Views)
