MATRIXx
using interactive animation with Version 7.1
I have a MATRIXx superblock that I would like to animate and test. I viewed the block using System build which came with MATRIXx 7.1 running on Windows. I added input and output ICONS from the animation pallette and I saved the block along with inputs and outputs to an RTF file in c:\Temp. When I used version 5 of MATRIXx, I recalled being able to load an RTF file into ISIM and simulating it. I noticed there is an animation builder that is provided along with xmath so I selected that and the standard Interactive Animation window came up. I selected RTF file and tried to load the file but it said that "Error reading system build RTF file". Is there an incompatibility somewhere. When I saved the file, i made sure just to save the superblocks and nothing else. Am I not saving things properly. Appreciate some help on this. Thanks! The RTF file is provided as an attachment.
Pavan
(7,314 Views)
Hi Pavan,
I could open it in build 3518 (newest build is 3718). Just go to File, Open.. and choose the pull-down to filter for RTFs. I got one continuous and one discreet SB. Is that correct?
Richard
Applications Engineering
www.ni.com/support
Richard
Field Sales Engineer, New Jersey
(7,306 Views)
