MATRIXx
TPL string manipulation question
Question 1:
"\" is being used as scape charecter for double quote (")  in a constant string. How could one search for \ in a string?
The  following code produces the line in the red color:
@S1 = "s:\aaa\bbb"@
@S2 = "\" @
@IFF STRSTR(S1,S2)@
@S2=STRSTR(S1,S2)@
S2=@S2@
@ELSE@
Variable     --@S2@--    not found.
@ENDIFF@
Variable    --"--    not found.
Question 2:
Is there a TPL function to extract subpart of a string (e.g., the first 5 characters)?
Question 3:
Is there a TPL function to extract file name and path (e.g., for "S:\aaa\foo.c" extracts S:\aaa and bbb.c )?
Farshid
(11,726 Views)
Hello Farshid,
      Have you had a chance to look at the MatrixX Template Programming Language Users Guide?  Please take a look at the example on pg 2-31.
Cheers,
NathanT
(11,712 Views)
I had already looked at the document and section that you mentioned - it  does not provide any answer to my questions.
Farshid
(11,700 Views)
Hello Farshid,
       Regarding Question 1:
It is not currently possible to create a string that only has a backslash character.  I will let R&D know about this and post the CAR ID.
       Regarding Questions 2&3:
       Unfortunately, there are no additional string manipulation TPL functions and definitely no filename manipulation routines. I'd suggest that if you must use pathnames, that you keep the path and the filename in separate variables and combine them only when you need to manipulate the file. That way, the TPL code and independently access the filename and path. Also, you might want to consider using user parameters, which is a way to get user data specified in a model diagram into TPL for processing. You could have a user parameter for the path and another for the filename.
I will file a product suggestion for more string manipulations and pathname functions.
Cheers,
NathanT
(11,695 Views)
Thanks Nathan.
I am attaching a TPL segment (poor man solution) that will extract the path and file name from a string representing the full file name (including the path).
The script uses the very limited set of functions that are available.
Note that since it is not currently possible to create a string that only has a backslash (\) character,  it only works on unix style file path (with /).
Farshid
(11,685 Views)
Farshid,
This was reported to R&D (# 46CQ5ZQ) for further investigation.  Thanks for the feedback!
NathanT
(11,653 Views)
