MATRIXx
Stand Alone Simulation
Hi
I am using MATRIXx 7.0 on Windows NT platform.
I found problem in Stand Alone Simulation of code generated by AutoCode as mentioned in ch2 of AutoCode user guide.
I didn't get file compile_c_sa.bat in dir c:\wind\mx_70.1\case\acc \src to compile sa files into object file.
Also the compilation command CL O1 ... gives 6 linking error about undefined function such as Implementation_initialization ,Background,initialize_input,initialize_output,error etc.
So i think I am able to generate Object file of model but it gives linking error.
This is what as per mentioned in older manual, the latest manual suggests acmake command which it doesn't recognize.
Regards
Ishant Dave
(7,646 Views)
The compile_c_sa.bat file was replaced with acmake.bat in later versions of MATRIXx.
acmake is located in the %ISIHOME%/bin directory.
If you can't find it, you can download a copy of the file from here. It's from a newer version but it may work:
http://digital.ni.com/public.nsf/websearch/082D458ADD08826E86256E92007C2C26?OpenDocument
--Paul Mandeltort
Automotive and Industrial Communications Product Marketing
(7,631 Views)
