I believe that there are several things that you will need to do. I am checking on them since I did not find a lot explicit in the manual.
First, Like the C++ compiler, I believe that you will need to set the environment variables for the Compiler path, lib and include. This will enable the compiler to be called from the command line as is the C++ Compiler. There are probably instructions with the compiler on how to do this operation.
I believe that the compatible compiler is the Visiual FORTRAN from Microsoft. Version 6 maybe.
Second, you may need to take a look at the makefile.mk and ensure that the appropriate changes are made.
Finally, I think you need to call the fortran function from a C wrapper, appropriately
configuring the User Code Block.
Again, I hope that I hear some more definitive information back from whom I asked, once I do I'll let you know.
There are some example files attached passed to me from a user "Chris" in Canada.
Garrett Thurston
gthurston@foliage.com
Phone: 781.993.5540
