MATRIXx
External output appearance - System build
We have been wondering for a while now how to fix the appearance of our external outputs. Once in a while, external outputs move to the right end of the "superbloc area". This is not due to a lack of space for the line to appear... Anybody knows how to fix this?
Thank you!
Karina
Message 1 of 8
(9,777 Views)
Do you have a graphic example you can attach?
Garrett Thurston
gthurston@foliage.com
Phone: 781.993.5540
Message 2 of 8
(9,777 Views)
Hello!
Here is a portion of a superblock where it occurs...
I hope you will know what this is due to!!!
Thanks!
Karina
Message 3 of 8
(9,777 Views)
It looks as though the inputs and outputs go off the page. What happens when you activate the SystemBuild Editor window and type the letter "f" for fit? What version is this is it Version 7.0?
Garrett Thurston
Phone: 781.993.5540
Message 4 of 8
(9,777 Views)
Jeepers! You got a lot of connections you have to make.
Thank god for the connection editor! I have only seen one other model with as many connections, it was a model from SR. One thing was that it took a bit of time for the screen to refresh, although with some of the graphic windowing features that were originally put into the tool one could move things around without having it refresh as you went it would only do it when you released the blocks or block but there was a specific key sequence. It might have been highlight blocks you want to move then hold down the ctrl key and then left click on the collection of blocks and drag. I'd have to get a version of Mx and try it to get the exact sequence.
Garrett Thurston
Phone: 781.993.5540
Message 5 of 8
(9,777 Views)
As a matter of fact, there is a lot of connections! However, Matrixx does not handle it to badly...as long as I don't forget to use the vector or bundle input/output option...
For the "fit to screen" option, it does the exact same thing when I use it... Connections still go "out of the window"! I am using version 7.0.
Message 6 of 8
(9,777 Views)
if you click in white space and then type "R" which the cursor roughly in the middle of the screen with it
still in white space, does it help bring the input/output connections on screen. Is there a 7.0 feature that is being used?
Garrett Thurston
Phone: 781.993.5540
Message 7 of 8
(9,777 Views)
Unfortunatly, it doesn't help... The connections remain the same...
It's a really weird problem isn't it?
Just for your info, I am not the only one having this problem here... Maybe it is something in version 7 we are doing. I don't think we have modified any of the initial settings...
Thanks again for trying to help!!!
Message 8 of 8
(9,777 Views)
