Linux Users
nidaqmxbase -- linux 64 bit
I keep following the software releases and hope for the day, where I can use my USB-6008 on a current ubuntu. I've tried a lot of times but everytime some module wants another module where the precomiled object files are only 32 bit...
My current solution is a virtual machine with an ancient Suse, which reads out the device and fires the data through the network to localhost... This is disgusting and ugly, but works...
Now I stumbled upon the new nidaqmxbase where it says that 64 bit kernel support was added. What does that now mean?
I would really like to give it another try, if there is a hint that I might succeed... So my question is:
What modules are needed to get a C application running on a 64-bit system which interacts with the usb-6008 device?
In my virtual machine it looks like that:
nipxirmk          115082  1
nidimk            321687  2 nipxirmk
niorbk             95523  2 nipxirmk,nidimk
nipalk           1222560  5 nipxirmk,nidimk,niorbk
nikal              75951  1 nipalk
Do I need all these? I mean, there is a noarch version of nikal and 64 bit versions of nivisa, nipal, but the rest is all 32-bit (or i386)...
Actually, all I want is to read analog values... I'm desperate...
Btw.: Is Kernel 3.0 support planned?
Markus
(8,755 Views)
While nikal will support 3.0 kernel, I don't think it'll help you access USB. You can potentially access it via daqmxbase.
Related thread:  https://decibel.ni.com/content/message/31331#31331
Is daqmxbase not working for you? I don't personally handle daqmxbase, so I don't know exactly what you need there.
(4,543 Views)
nipxirmk          115082  1
Hi Markus,
Those modules are required for VISA to communicate with PCI/PCIe devices. VISA installs support for both PCI/PCIe and USB devices and does not allow individual installation for each bus. Since DAQmx Base uses VISA for device I/O, you need them even though USB device communication over VISA doesn't use them.
DAQmx Base 3.5 [1] did indeed add support for 64-bit kernels. What this means is DAQmx Base includes both 32-bit and 64-bit kernel modules instead of only 32-bit kernel modules. However, the universal bitness stops at the kernel -- the user-mode libraries (libnidaqmxbase.so et al) are still 32-bit. This means you will need 32-bit system libraries as well (glibc.so and libstdc++.so are the bare minimum).
Finally, DAQmx Base still does not support Ubuntu -- the most recent distributions that the driver supports are RHEL 6 and openSuSE 11.3, and the only 64-bit distributions supported are RHEL 5 and RHEL 6. All of the distribution information is available in the readme [2].
[1] NI DAQmx Base 3.5
http://joule.ni.com/nidu/cds/view/p/id/2893/lang/en
[2] NI DAQmx Base 3.5 readme
http://ftp.ni.com/support/softlib//multifunction_daq/nidaqmxbase/3.5/Linux/README.txt
Joe Friedchicken
NI Configuration Based Software
Get with your fellow OS users
[ Linux ]
Principal Software Engineer :: Configuration Based Software
Senior Software Engineer :: Multifunction Instruments Applications Group (until May 2018)
Software Engineer :: Measurements RLP Group (until Mar 2014)
Applications Engineer :: High Speed Product Group (until Sep 2008)
(4,543 Views)
I was wondering if the support for 64-bit kernels has changed with daqmx base 3.6. I've been trying to install it on Scientific Linux 6.4 x86_64, and it hasn't been working very well. Is this supported at all?
(4,543 Views)
Are you having different problems than what you posted here?
Error compiling examples from DAQmx Base 3.6 on Scientific Linux 6.4 x86_64
http://forums.ni.com/t5/LabVIEW/Error-compiling-examples-from-DAQmx-Base-3-6-on-Scientific-Linux/m-p...
Joe Friedchicken
[ Linux ]
(4,543 Views)
