Linux Users
libnipalu.so failed to initialize - OPENSUSE 42.2 NI-VISA 17.0
I've been trying to setup NIVISA17.0 in opensuse 42.2 and  i finish as following step
zcat /boot/symvers-<version>.gz > Module.symvers
make cloneconfig
make modules_prepare
updateNIDrivers
and i setup :pip install nivisa
import visa
rm = visa.ResourceManager()
 but it's giving me the following error:
Perhaps you need to run updateNIDrivers
Aborted (core dumped)
 when i
The same happens even after I run updateNIDrivers
and here is the output from rpm -qa|grep "^ni"
ni-apal-errors-17.0.0.49152-0+f0.noarch
ni-pxirm-17.0.0.49155-0+f3.x86_64
nissli-32bit-17.0.0-f0.x86_64
ni-pal-17.0.0.49152-0+f0.x86_64
niiotracei-17.0.0-f0.x86_64
ni-mdbg-nikalmod-17.0.0.49152-0+f0.x86_64
nitargetcfgi-3.0.0-f1.x86_64
nispylogsupp-32bit-17.0.0-f0.x86_64
ni-pxipf-errors-17.0.0.49152-0+f0.noarch
ni-pal-32bit-17.0.0.49152-0+f0.x86_64
ni-visa-sysapi-17.0.0.49152-0+f0.x86_64
nivisaserver-17.0.0-f0.i386
nirocoerri-17.0.0-f1.i386
ni-orb-nikalmod-17.0.0.49152-0+f0.x86_64
ni-mdbg-17.0.0.49152-0+f0.x86_64
nipalki-17.0.0.49152-0+f0.noarch
nisvcloc-17.0.0-1.noarch
nipxipfi-17.0.0.49155-0+f3.noarch
ni-mxdf-32bit-17.0.0.49152-0+f0.x86_64
ni-mdbg-errors-17.0.0.49152-0+f0.noarch
ni-mxdf-nikalmod-17.0.0.49152-0+f0.x86_64
nimdnsresponder-17.0.0-f0.i386
nisyscfgi-17.0.0-f0.x86_64
ni-pxirm-resources-17.0.0.49155-0+f3.noarch
nivisa-config-17.0.0-f0.i386
nipxipfki-17.0.0.49155-0+f3.noarch
ni-kal-17.0.0.49152-0+f0.noarch
ni-pal-nikalmod-17.0.0.49152-0+f0.x86_64
ni-orb-32bit-17.0.0.49152-0+f0.x86_64
ni-mdbg-32bit-17.0.0.49152-0+f0.x86_64
nivisa-32bit-17.0.0-f0.x86_64
nidimi-32bit-17.0.0-f0.x86_64
ni-orb-errors-17.0.0.49152-0+f0.noarch
ni-orb-17.0.0.49152-0+f0.x86_64
nisslcerts-17.0.0-3.0.noarch
nivisak-17.0.0-f0.x86_64
nispylogsupp-17.0.0-f0.x86_64
nisyscfgi-32bit-17.0.0-f0.x86_64
nidimki-17.0.0-f0.x86_64
nidimi-17.0.0-f0.x86_64
nivisa-devel-17.0.0-f0.i386
nissli-17.0.0-f0.x86_64
ni-pxirm-nikalmod-17.0.0.49155-0+f3.x86_64
nivisa-17.0.0-f0.x86_64
ni-visa-sysapi-32bit-17.0.0.49152-0+f0.x86_64
ni-mxdf-errors-17.0.0.49152-0+f0.noarch
nicurli-17.0.0-f0.x86_64
nispyi-2.8.1-f0.i386
nicurli-32bit-17.0.0-f0.x86_64
ni-pal-errors-17.0.0.49152-0+f0.noarch
ni-mxdf-17.0.0.49152-0+f0.x86_64
and i found some setup log file in TMP in attachment
Thanks for your time!
(3,587 Views)
What are the results of "lsmod | grep ni" and "modprobe nikal"?
(3,566 Views)
Thanks for you responsed.
The return message as following:
linux-2hkh:~ # lsmod |grep ni
ghash_clmulni_intel 16384 0
cryptd 20480 1 ghash_clmulni_intel
linux-2hkh:~ # modprobe nikal
linux-2hkh:~ #
and i found
linux-2hkh:~ # cd /usr/src/
linux-2hkh:/usr/src # ls -l
total 4
lrwxrwxrwx 1 root root 19 Sep 26 02:30 linux -> linux-4.4.104-18.44
drwxr-xr-x 1 root root 598 Sep 26 02:33 linux-4.4.104-18.44
drwxr-xr-x 1 root root 12 Sep 26 02:30 linux-4.4.104-18.44-obj
drwxr-xr-x 1 root root 12 Sep 26 02:30 linux-obj
drwxr-xr-x 1 root root 132 Sep 26 02:37 ni-pxipf
drwxr-xr-x 1 root root 70 Sep 25 05:24 packages
linux-2hkh:/usr/src # uname -r
4.4.104-18.44-default
the kernel version is 4.4.104-18.44-default but in /usr/scr/  folder doesn't have the same name ,if this is the issue?
(3,562 Views)
This is a known issue.  Please see the resolution at http://digital.ni.com/public.nsf/allkb/AB92119277C041FE86257FAB005446AC?OpenDocument.
Alternatively, you could try installing the 18.2 version of NI-VISA.  This will require you to ./UNINSTALL the existing driver distribution.  Then, follow the general directions at http://www.ni.com/product-documentation/54754/en/, installing rpm_OpenSUSE422.rpm from https://www.ni.com/en/support/downloads/drivers/download.ni-linux-device-drivers.html#349660 and doing "zypper install ni-visa".  It works fine for me on 42.2, and you don't have to do any of the other preliminary steps, either.
(3,549 Views)
