Linux Users
an other Umbuto 12.04 install help question :)
Hi all
i have read some of the other threds here on the forum, where i downloaded the NI-Visa.5.4.0.iso and unpacked it.
when i runned the installer, it started up but i did not install any thing, the folder is there but nothing in it, here is the how it looks
i have just started with linux so i have no clue how to fix this issue.
Br
Bre
  NI-VISA for Linux
     version 5.4.0f0 for Linux
National Instruments products support the following Linux distributions:
   openSUSE
   Red Hat Enterprise Linux Desktop + Workstation
   Scientific Linux
Refer to README.txt for the latest information at the time of release.
Refer to www.ni.com/linux for the most recent information about Linux
support at National Instruments.
Continue? [Yn] Y
Checking required install tools...
Checking installer tool versions...
rpm        Not found in current path
tar        1.26
Checking dependencies...
glibc      2.15
Unpacking install files to /tmp/nivisa-5.4.0f0.install...
### all the agreement stuff
NI-VISA for Linux version 5.4.0f0
is about to be installed using rpm at /usr/local/natinst
./INSTALL: line 1515: -q: command not found
Would you like to continue? [Yn] Y
Installing NI-VISA for Linux version 5.4.0f0...
Pre Installation .
Post Installation .
./INSTALL: line 419: --showrc: command not found
./INSTALL: line 667: -qp: command not found
Pre Installation ...................................
Post Installation ...................................
FOR PATENTS COVERING NATIONAL INSTRUMENTS PRODUCTS, REFER TO
THE PATENTS.txt FILE ON /home/CORPUSERS/23049829/test AND/OR
www.ni.com/patents
NI-VISA for Linux Installation completed successfully.
(6,928 Views)
forgot to mention that i unpacked the iso in my home folder and, started the install from there.
Br
Bre
(5,120 Views)
Your problem is rpm Not found in current path
Ubuntu is deb package based distribution not rpm.
You should read thread about how install NI-VISA on deb based distribution.
(5,120 Views)
thank you for the fast answer, im learning linux as we speak   gone see if i can find the thread your recomending.
(5,120 Views)
was looking at this one,https://decibel.ni.com/content/docs/DOC-6742  but its only for 32Bit, and i have a 64Bit umbot machine
even though i used Alien to convert the RPM to DBM i got stuck due too the installer did not fint the files..
i probobly gone do an ugly version with a ptyhon server on my win machine with the instrument, and send the info back to the linux, not a fun solution 😕 but i cant spend days on trying to figure out, and learn at the same time... was hoping for an easy tutorial or solution
(5,120 Views)
More information about 64-bit.
I have installed NI-VISA on Mageia Linux 2 64-bit without problems. It is rmp distro similar to RedHat Linux.
NI-VISa configuration utility also works, but I don't discover if I can create LabView application with VISA.
I think the best way is try to install NI-VISA on 64-bit rpm based distro (RadHat, OpenSUSE and Scientific Linux are officially supported)
(5,120 Views)
I wonder why NI doesn't manage that trivial task of providing .deb packages.
Seriously, that's really easy.
Linux Embedded / Kernel Hacker / BSP / Driver development / Systems engineering
(3,782 Views)
