Linux Users
PXI-8431
Has anyone been successful in getting any PXI-8431 variant working in Linux or would like to try?
Disregarding that nobody ever responded to http://forums.ni.com/t5/Linux-Users/PXI-8431-4-installation-on-Linux/gpm-p/3407591 from two and a half years ago, I would like to get the PXI-8431/2 working.
According to this document, RS-485 support is not ruled out:
USING PCI SERIAL WITH LINUX
http://www.ni.com/pdf/manuals/322539a.pdf
However, as in the post referenced, the PXI-8431/2 lists no I/O port addresses, only one memory range in region 0 via lspci.  Has anyone uncovered any I/O port addresses?
I am using Ubuntu 14.04 with kernel 4.4.0-64-generic, as this is all that I am allowed to use in my work environment currently.
(4,354 Views)
Hi JStern,
Have you seen this tutorial?
Instrument Control in Linux Tutorial
http://www.ni.com/tutorial/2816/en/
It seems like the main limitation will be driver support, and as far as I know Ubuntu is unsupported. Have you been able to install NI Serial or NI VISA?
Austin E.
Notes for Branch AE:
Please reply to This Post within 24 hours
The US AE is expected to reply to all of your posts within 24 hours. Having this expectation will keep the escalation moving quickly and toward a fast resolution.
You can also use other communication channels: Phone, Skype, etc. to discuss the issue with the US AE. This can help with troubleshooting and quick diagnosis of the issue.
Click here to provide kudos for a post on this page
(4,332 Views)
So, NI-VISA 16.0 and DAQmx 15.0 are both installed, giving a VISA address to our DAQ card. The NI-Serial package for Linux (1.0, circa 1999) is identical to the package referenced in Using PCI Serial with Linux (also circa 1999), as I referenced in my original post: the included code only works if the serial device has an I/O port address already available in the operating system.
You are correct that the main limitation is driver support; this is why I ended up on the forum after several NI service requests.
You can see the Linux NI Serial code for yourself:
from Using PCI Serial with Linux
ftp://ftp.ni.com/support/serial/linux/
NI-Serial 1.0 - Linux
http://www.ni.com/download/ni-serial-1.0/780/en/
(4,314 Views)
