Linux Users
PCI 6534 not found anymore
Hi all,
I had a PCI 6534 plugged into a Linux machine running OpenSUSE 11.2 with a realtime patch. It was working earlier this year using the NI-DAQmx 8.0.2, but ever since it was transfered to another machine (running Windows with LabView 2011) and back, it stopped working. I tried to put it back to the Windows machine to see if there was anything I could do through MAX, but it was not successful. Also tried running updateNIDrivers without any luck.
lspci finds the card
nilsdev does not return anything
lsdaq can't be found in the system
all modules seem to be up and running according to https://decibel.ni.com/content/docs/DOC-15450
I'm working on reinstalling the drivers now. Any help is welcome.
Edit:
"uname -a": Linux grable20 2.6.33.7.2-rt30-0.1-desktop #1 SMP PREEMPT RT Mon Mar 19 10:32:32 EDT 2012 i686 i686 i386 GNU/Linux
running "nidaqmxconfig --export config" as in http://forums.ni.com/t5/Digital-I-O/nidaqmxconfig-gives-error-2147220712/m-p/1007441/highlight/true#... gives "Error -2147220721"
running "DAQmxTestPanels" gives
"Can't load LabVIEW runtime library /usr/local/lib/liblvrt.so.8.0
libOSMesa.so.4: cannot open shared object file: No such file or directory"
(4,406 Views)
Reinstallation step-by-step
- Uninstalling the drivers
     lsmod (shows ni module)
     wget http://ftp.ni.com/support/softlib/multifunction_daq/nidaqmx/8.0.2LinuxOnly/DAQmx802f0.iso
     mkdir -p /mnt/iso
     sudo mount -t iso9660 -o loop DAQmx802f0.iso /mnt/iso
     sudo /mnt/iso/UNINSTALL
     lsmod (shows no ni module)
     sudo /sbin/reboot
     lsmod (still shows no ni module - ok)
- Start following these instructions https://decibel.ni.com/content/docs/DOC-15450
- Install NI-KAL
     cd lucas/spi/
     mkdir DAQmxInstall
     cd DAQmxInstall
     mkdir VISA
     cd VISA
     (skipping the installation of tools and kernel source since that was already done)
     cd rpm
     sudo rpm -ivh nikali-2.0.0-f0.noarch.rpm
     cd /usr/local/natinst/nikal/bin
     . nikaliInstallerUtility.sh
     nikaliPostInstall (gives error about not being root when running /usr/local/bin/updateNIDrivers)
     sudo /usr/local/bin/updateNIDrivers
     sudo /sbin/reboot
     (rebooting)
     sudo modprobe nikal
     lsmod (nikal is there - "nikal                  59011  0")
- Install DAQmx with the script
     cd lucas/spi/DAQmxInstall/DAQmx (to daqmx path)
     sudo ./INSTALL --nodeps
     [y, y, y, <enter>, y, <enter>, y, <enter>, y, <enter>, y, (installing...)]
     (NI-DAQmx for Linux Installer Distribution Installation completed successfully.)
     sudo /sbin/reboot
     (rebooting...)
     cd /lib/modules/$(uname -r)/build/include/linux
     sudo ln -s ../generated/utsrelease.h
     sudo ln -s ../generated/autoconf.h
- Re-install NI-KAL
     cd lucas/spi/DAQmxInstall/VISA/rpms
     sudo rpm -e --nodeps nikali
     nikaliPostInstall (gives error about not being root when running /usr/local/bin/updateNIDrivers. trying again as sudo su)
     sudo su -
     nikaliPostInstall ("WARNING: could not unload module nimru2k from memory"? "WARNING: could not unload module nipxirmk from memory"?)
     sudo /sbin/reboot
     (rebooting...)
     sudo su -
     ./updateNIDrivers ("WARNING: could not unload module nimru2k from memory"? "WARNING: could not unload module nipxirmk from memory"? Said yes to rebooting)
     (rebooting...)
     lsmod | grep ni (ALMOST exactly the same)
     ("nimru2k               427897  1
     nimxpk                 33632  0
     nipxirmk              115018  1
     nidimk                320599  4 nimru2k,nipxirmk
     nimsdrk               231242  0
     nidmxfk               373944  1 nimsdrk
     nimxdfk               477896  4 nimru2k,nimsdrk,nidmxfk
     nimstsk                78141  2 nimsdrk,nidmxfk
     nimdbgk               360232  6 nimru2k,nimsdrk,nidmxfk,nimxdfk,nimstsk
     niorbk                 95647  8 nimru2k,nipxirmk,nidimk,nimsdrk,nidmxfk,nimxdfk,nimstsk,nimdbgk
     nipalk               1225168  13 nimru2k,nimxpk,nipxirmk,nidimk,nimsdrk,nidmxfk,nimxdfk,nimstsk,nimdbgk,niorbk
     nikal                  59011  1 nipalk")
     nilsdev (doesn't return a single thing)
     sudo nilsdev (doesn't return a single thing)
     /sbin/lspci ("04:02.0 Class ff00: National Instruments Device 12b0 (rev 01)")
     sudo find / -name lsdaq (returns nothing)
(3,263 Views)
