Linux Users
NI-DAQmx for Linux support for additional cards needed
I have an LabVIEW application that runs on Linux which has used NI-DAQmx v8.0.2 to do data acquisition from a NI-PCI-6071E for many years. I recently have been requested to implement some new instances of this system.
Upon looking at NI's product lineup I noticed two things:
1) the PCI-6071E isn't sold anymore and
2) the replacment cards (PCIe-6353 and PCIe-6363) are not supported by NI-DAQmx v8.0.2 (or by NI-DAQmx base)
No other NI DAQ cards will meet my applications specs (except the PCI-6255 which isn't support either). Am I completely out of luck? Is NI adding Linux NI-DAQmx support for any of their new DAQ cards?
Windows OS is NOT an option.
Thanks.
(5,574 Views)
I think your way is to switch your application to NI-DAQmxBase. Firstly, you should read NI-DAQmxBase specification, because it has some limitations compare to NI-DAQmx. For example: DMA support are missing for correlated digital output/input - it speed is limited by computer speed 100kHz. Read it and check if it met you application specs.
In case, of text programming language (C/C++, Pascal) switching to NI-DAQmxBase is not hard, but in Labview it will be terrible.
In one application I have PCI-6224 (NI-DAQmxBase) and it works perfectly.
(4,898 Views)
Thanks for your reply.
It is my understanding that none of the NI DAQ cards that meet my specifications are supported by NI-DAQmx base (PCI-6255, PCIe-6353, PCIe-6363).
Is this not true? The card you mentioned, the PCI-6224, is explicitly supported (http://download.ni.com/support/softlib//multifunction_daq/nidaqmxbase/14.0/Linux/README.txt).
(4,898 Views)
What about PCI-6259? It probably mets your specs - difference is less number of analog channels.
And also is not make sence that PCI-6255 is not supported, because all card from M-Series probably supported by NI-DAQmxBase.
My mention about of PCI-6224 only an example in my application.
(4,898 Views)
One the hard specs for my application is a minimum of 32 differential input channels.
(4,898 Views)
Ask directly, your local NI repesentant if PCI-6255 supporeted under Linux.
PCI-6259 has 40 digital lines: 32 - hardware timed  , 8 - software clocked.
Next solution will be to use two cards to pass specs.
(4,898 Views)
