Linux Users
NI-DAQmx Base 15.0 on Ubuntu 14.04 LTS 64 bit
I'm trying to get NI-DAQmx Base installed on Ubuntu 14.04 LTS 64 bit to use the C-Api and get the usb drivers.
Using Alien I could install the packages like mentioned here: http://maztories.blogspot.de/2013/03/ni-usb-6008-card-can-be-installed-in.html
When running lsdaq I get the following error:
$ lsdaq
Detecting National Instruments DAQ Devices
Found the following DAQ Devices:
Error Message =Internal Warning 0x08B1734C :  "lvinit.cpp", line 2181
LabVIEW version 15.0f1
For assistance in resolving this problem, please contact National Instruments Support.
/usr/local/bin/lsdaq: line 7:  3271 Aborted                 (core dumped) /etc/natinst/nidaqmxbase/bin/daqmxbase_listdevices
Does anyone know how to fix this?
I know Ubuntu is not supported but I have to use it.
Any help would be greatly appreciated.
(9,666 Views)
The log says the core was dumped. Did you save the core? If so, is it possible to send it?
(8,948 Views)
Hey,
thanks for the reply.
I do have the core. I could send it per mail if that is okay.
(8,948 Views)
has this been solved? I get the same error on Debian 8.0 64bit.  I get this error on lsdaq and also on own applications linked with liblvrtdark.so.15.0 64bit.
(8,806 Views)
Possibly this is caused by shell install scripts calling /bin/sh and using bash-specific syntax. "ln -sf bash /bin/sh" before install solved it. If this is the cause, the install scripts should be calling /bin/bash instead of /bin/sh.
https://wiki.ubuntu.com/DashAsBinSh
(8,752 Views)
