Linux Users
Linux preference
In case of Centos 6.5, I think that error is connected with different version of rpm packages older NI-VISA and newer CentOS 6.5
My "winning" combination of rpm distribution is Mageia 2 32/64-bit and Scientific Linux 6.4 32-bit.
Note: you should install kernel-headers package before instaling NI-VISA.
Message 11 of 49
(2,540 Views)
Hello Mig-31,
Can you communicate using USB?
Thanks for your advice!
Jorge Amaral
Software developer
www.mcm-electronics.com
PORTUGAL
Message 12 of 49
(2,540 Views)
Hello Jorge,
What you mean under USB communication? Because usually there is USB->serial communication adapter, which creates /dev/ttyUSB0 for example. This type of communication usually only about system driver.
Message 13 of 49
(2,540 Views)
Hello again,
Till now I was able to communicate with my Arduino (don't know if you know this device) using it's software using /dev/ttyACM0. I also tried with a USB-serial adapter that also worked. But I never could do that in Labview.
I created a static link in "visaconf". But I never could open the port without error (and the motherboard opens correctly). Using "NIvisaic", I can see the USB device listed (because of the static link) but with a question mark on the top.
Do you know any tip that could help me at this point?
Thanks!
Software developer
PORTUGAL
Message 14 of 49
(2,540 Views)
Hello again,
I can serial device to VISA using VISA configuration utility. I can't discover it in Labview, because I don't any device with serial communication. I usually use communication over TCP.
Message 15 of 49
(2,540 Views)
Jorge,
What error do you get when you attempt to use the statically-created entry? Also important, what are the permissions/ownership of the device itself, and finally which user is running LV?
Post the output of the following (with Arduino plugged in and LabVIEW running) from a terminal/console:
ls -l /dev/tty*
ps -e | grep -i labview
Message 16 of 49
(2,540 Views)
Hello Brad,
I'm not using Labview development. I'm only using NIvisaic to test the serial port. Because of that, I think that the second command won't work (I teste and didn't worked ).
About the permissions I always do this:
0. su/pass
1. chmod /dev/ttyACM0
2. chmod /dev/ttyS0
3. chmod /dev/ttyS1
And they after configuring in "visaconf" they all apper listed on "NIvisaic". But I only can open the two serial ports of the motherboard. I can't open the USB port.
ls -l /dev/tty*
crw-rw-rw-. 1 root tty       5,  0 Jan 31 14:32 /dev/tty
crw--w----. 1 root tty       4,  0 Jan 31 14:32 /dev/tty0
crw--w----. 1 root tty       4,  1 Jan 31 14:33 /dev/tty1
crw--w----. 1 root tty       4, 10 Jan 31 14:32 /dev/tty10
crw--w----. 1 root tty       4, 11 Jan 31 14:32 /dev/tty11
crw--w----. 1 root tty       4, 12 Jan 31 14:32 /dev/tty12
crw--w----. 1 root tty       4, 13 Jan 31 14:32 /dev/tty13
crw--w----. 1 root tty       4, 14 Jan 31 14:32 /dev/tty14
crw--w----. 1 root tty       4, 15 Jan 31 14:32 /dev/tty15
crw--w----. 1 root tty       4, 16 Jan 31 14:32 /dev/tty16
crw--w----. 1 root tty       4, 17 Jan 31 14:32 /dev/tty17
crw--w----. 1 root tty       4, 18 Jan 31 14:32 /dev/tty18
crw--w----. 1 root tty       4, 19 Jan 31 14:32 /dev/tty19
crw-------. 1 root root      4,  2 Jan 31 14:33 /dev/tty2
crw--w----. 1 root tty       4, 20 Jan 31 14:32 /dev/tty20
crw--w----. 1 root tty       4, 21 Jan 31 14:32 /dev/tty21
crw--w----. 1 root tty       4, 22 Jan 31 14:32 /dev/tty22
crw--w----. 1 root tty       4, 23 Jan 31 14:32 /dev/tty23
crw--w----. 1 root tty       4, 24 Jan 31 14:32 /dev/tty24
crw--w----. 1 root tty       4, 25 Jan 31 14:32 /dev/tty25
crw--w----. 1 root tty       4, 26 Jan 31 14:32 /dev/tty26
crw--w----. 1 root tty       4, 27 Jan 31 14:32 /dev/tty27
crw--w----. 1 root tty       4, 28 Jan 31 14:32 /dev/tty28
crw--w----. 1 root tty       4, 29 Jan 31 14:32 /dev/tty29
crw-------. 1 root root      4,  3 Jan 31 14:33 /dev/tty3
crw--w----. 1 root tty       4, 30 Jan 31 14:32 /dev/tty30
crw--w----. 1 root tty       4, 31 Jan 31 14:32 /dev/tty31
crw--w----. 1 root tty       4, 32 Jan 31 14:32 /dev/tty32
crw--w----. 1 root tty       4, 33 Jan 31 14:32 /dev/tty33
crw--w----. 1 root tty       4, 34 Jan 31 14:32 /dev/tty34
crw--w----. 1 root tty       4, 35 Jan 31 14:32 /dev/tty35
crw--w----. 1 root tty       4, 36 Jan 31 14:32 /dev/tty36
crw--w----. 1 root tty       4, 37 Jan 31 14:32 /dev/tty37
crw--w----. 1 root tty       4, 38 Jan 31 14:32 /dev/tty38
crw--w----. 1 root tty       4, 39 Jan 31 14:32 /dev/tty39
crw-------. 1 root root      4,  4 Jan 31 14:33 /dev/tty4
crw--w----. 1 root tty       4, 40 Jan 31 14:32 /dev/tty40
crw--w----. 1 root tty       4, 41 Jan 31 14:32 /dev/tty41
crw--w----. 1 root tty       4, 42 Jan 31 14:32 /dev/tty42
crw--w----. 1 root tty       4, 43 Jan 31 14:32 /dev/tty43
crw--w----. 1 root tty       4, 44 Jan 31 14:32 /dev/tty44
crw--w----. 1 root tty       4, 45 Jan 31 14:32 /dev/tty45
crw--w----. 1 root tty       4, 46 Jan 31 14:32 /dev/tty46
crw--w----. 1 root tty       4, 47 Jan 31 14:32 /dev/tty47
crw--w----. 1 root tty       4, 48 Jan 31 14:32 /dev/tty48
crw--w----. 1 root tty       4, 49 Jan 31 14:32 /dev/tty49
crw-------. 1 root root      4,  5 Jan 31 14:33 /dev/tty5
crw--w----. 1 root tty       4, 50 Jan 31 14:32 /dev/tty50
crw--w----. 1 root tty       4, 51 Jan 31 14:32 /dev/tty51
crw--w----. 1 root tty       4, 52 Jan 31 14:32 /dev/tty52
crw--w----. 1 root tty       4, 53 Jan 31 14:32 /dev/tty53
crw--w----. 1 root tty       4, 54 Jan 31 14:32 /dev/tty54
crw--w----. 1 root tty       4, 55 Jan 31 14:32 /dev/tty55
crw--w----. 1 root tty       4, 56 Jan 31 14:32 /dev/tty56
crw--w----. 1 root tty       4, 57 Jan 31 14:32 /dev/tty57
crw--w----. 1 root tty       4, 58 Jan 31 14:32 /dev/tty58
crw--w----. 1 root tty       4, 59 Jan 31 14:32 /dev/tty59
crw-------. 1 root root      4,  6 Jan 31 14:33 /dev/tty6
crw--w----. 1 root tty       4, 60 Jan 31 14:32 /dev/tty60
crw--w----. 1 root tty       4, 61 Jan 31 14:32 /dev/tty61
crw--w----. 1 root tty       4, 62 Jan 31 14:32 /dev/tty62
crw--w----. 1 root tty       4, 63 Jan 31 14:32 /dev/tty63
crw--w----. 1 root tty       4,  7 Jan 31 14:32 /dev/tty7
crw--w----. 1 root tty       4,  8 Jan 31 14:32 /dev/tty8
crw--w----. 1 root tty       4,  9 Jan 31 14:32 /dev/tty9
crw-rw-rw-. 1 root dialout 166,  0 Jan 31 14:34 /dev/ttyACM0
crw-rw-rw-. 1 root dialout   4, 64 Jan 31 14:32 /dev/ttyS0
crw-rw-rw-. 1 root dialout   4, 65 Jan 31 14:32 /dev/ttyS1
crw-rw----. 1 root dialout   4, 66 Jan 31 14:32 /dev/ttyS2
crw-rw----. 1 root dialout   4, 67 Jan 31 14:32 /dev/ttyS3
3258 pts/0    00:00:02 NIvisaic
Software developer
PORTUGAL
Message 17 of 49
(2,540 Views)
The only thing I can think, since a device that's run through the CDC ACM system isn't a proper serial device (it just has some shared attributes) VISA doesn't like it since it is not able to support what it needs to do.
The USB-to-serial device should work properly, of course with either proper ownership/group settings (e.g. change the user that is running the software to be part of the "dialout" group) or change the permissions of the device to make that unneccessary (note: this is a security risk, if you plan on making this computer accessible to someone other than yourself, either by physical login or by remote access, and if this computer will be reachable by the Internet, assume that it will be remotely accessible since people will attempt to break into the system). If this machine is not meant to be used by others that you don't trust or will be insulated from the Internet, you can simply change the permissions on the device. Otherwise, change the user to be in the dialout group.
Message 18 of 49
(2,540 Views)
Thanks Brad,
But unfortunely I already tried with no success. First I try it in windows (and it works) and then in centos.
I don't have security issues. I'm just using this as a prototype. So I always do "chmod 666 /dev/ttyACM0".
This is very strange.
Software developer
PORTUGAL
Message 19 of 49
(2,540 Views)
Hello Jorge,
There is a possibility that this is a known issue with VISA 5.4. If you uninstall VISA 5.4 and then install VISA 5.3 you may have better luck recognizing your device correctly. In VISA 5.4 we added additional functionality for event based serial communication. However, for devices that do not respond to events VISA does not correlate them correctly in VISAIC which yields the behavior you are seeing. By reverting to the previous version this will ignore the changes based on event driven communication.
Ian M.
Message 20 of 49
(2,540 Views)
