Linux Users
Labview 2017 64 bits and CentOS 7 64 bits Visa Write problem
Hello friends
I'm very happy to install labview 2017 64 bits for linux into CentOS 7 - Both are perfect.
But I don't know why visa has a problem...I try many things, but no success.
The problem is, when a I run the same VI inn Windows 8.1 and labivew 2012 64bits all is perfect, but when a try into CentOS 7 the viwrite always return error.
Please, whats wrong with the Visa or Labview, I have no Idea whats wrrong.
Y try  this:
A1: Some action is required to make the existing NI-VISA installation
    work for the new kernel. After upgrading your kernel, run
    updateNIDrivers utility as root. The utility is located in
    /usr/local/bin. Be sure to have sources for your new kernel properly
    installed on your system before running the utility. The utility
    rebuilds the driver using the new kernel sources and copies it to
    the appropriate location for the new kernel. For the changes
    to take place, you will be asked to reboot your machine after the
    utility completes.
and all success, but still don't work.
I'm use first visa 15 and now visa 16 but the same problem
and when a Try to run visa I have TMO to try write into device.
Again, in W8.1 all is fine - no cable - no device... this is labivew/visa
(7,563 Views)
install visa2017 and try again,maybe you can use COM tools,to check your device was ok
(7,541 Views)
visa 201?
Where I can find?
(7,503 Views)
I have the same problem:
when I try to write on arduino  device the same timeout error get.
My OS is centos 7 , labview 2014 64 bit SP1, visa 15.5
Thanks in advance
(6,927 Views)
Hello dear friend!
NOw we have ni-visa 17. Please install the new visa into centos 7 - after install please reboot.
After this you will need to make sure you are a root and you in a group ( if you don't now what I'm talking abut please let me know)
after this open visa and check the number (usb0---1 etc)
Another problem is about the serial chip usage in arduino - must be ch340 or ftdi --if you using atmel doesnt work .
(6,915 Views)
Dont worry --works 100 % fine eith me without to much work around.
I can help you..
(6,915 Views)
how to install labview 2017 in centos? and as licensed by labview linux or did you use winehq to use the labview .exe in centos please
(3,901 Views)
