Linux Users
Installed NI-VISA 4.5 in Ubuntu 9.04
Hi
I was working on the Ubuntu 9.10 and it does not support rpm files. Shall I transform the rpm files into .det that is supported by Ubuntu? Thanks.
Message 21 of 24
(699 Views)
Kujo_Jotaro,
          You can try using alien to convert the rpm's to dep packages. I have done this in the past with limited success, but I didn't spend a whole lot of time trying to get it to work on Ubuntu.
Hope this help.
Ox
J. "Ox" Gibson
Systems Software / VISA Software Technician
That which doesn't kill me, better run REALLY fast.
Message 22 of 24
(699 Views)
Mr. Ox
Thank you very much.
These days I tried somehow to installed NI-VISA 4.5 &5.1 on Ubuntu "successfully", as the words in terminal told me again and again... However they seems not work when running our own project containing VISA modules and the error "NI-VISA not installed" just appears again and again. I am fully frustrated... Have you guys encountered with such problem? Thanks.
Message 23 of 24
(699 Views)
Kujo_Jotaro,
          Unfortunately, we do not support Ubuntu or any other deb based OS. I was trying to install to Ubuntu a few years back to see if it could be done. If I remember correctly, I only got it mostly working.
However, I had to put that on off at the time and have not had time to investigate any further. I would try to follow the steps in the tutorials at the following links:
https://decibel.ni.com/content/groups/search.jspa?peopleEnabled=true&userID=&containerType=&containe...
Let us know if that helps.
Ox
J. "Ox" Gibson
Message 24 of 24
(699 Views)
