Linux Users
Installation of NI-VISA on SLinux 6.0
I have just installed NI-VISA-5.1.2 on a CentOS 6 64 bits box (equivalent to SLinux 6). I follow these steps:
  yum install kernel-devel kernel-headers
  yum install glibc.i686 libgcc.i686
  KERNELHEADERS=/usr/src/kernels/2.6.32-220.7.1.el6.x86_64 ./INSTALL
and everything went fine. But updateNIDrivers fails for 3 modules niorbk.ko nidimk.ko nipxirmk.ko
Exemple for nipxirmk.ko :
  CC   /usr/local/natinst/nikal/src/client/nipxirmk-interface.o
  SHIPPED /usr/local/natinst/nikal/src/client/nipxirmk-processed.o
  LD   /usr/local/natinst/nikal/src/client/nipxirmk.o
ld: Relocatable linking with relocations from format elf32-i386 (/usr/local/natinst/nikal/src/client/nipxirmk-processed.o) to format elf64-x86-64 (/usr/local/natinst/nikal/src/client/nipxirmk.o) is not supported
make[2]: *** [/usr/local/natinst/nikal/src/client/nipxirmk.o] Erreur 1
make[1]: *** [_module_/usr/local/natinst/nikal/src/client] Erreur 2
make: *** [all] Erreur 2
ERROR: failed to build nipxirmk.ko
nipxirmk.ko failed to update.
It seems there is a mess between 64 bits and 32 bits files:
file /usr/local/natinst/nikal/src/client/*.o_shipped
/usr/local/natinst/nikal/src/client/nidimk-processed.o_shipped:   ELF 32-bit LSB relocatable, Intel 80386, version 1 (SYSV), not stripped
/usr/local/natinst/nikal/src/client/niorbk-processed.o_shipped:   ELF 32-bit LSB relocatable, Intel 80386, version 1 (SYSV), not stripped
/usr/local/natinst/nikal/src/client/nipalk-processed.o_shipped:   ELF 64-bit LSB relocatable, x86-64, version 1 (SYSV), not stripped
/usr/local/natinst/nikal/src/client/nipxirmk-processed.o_shipped: ELF 32-bit LSB relocatable, Intel 80386, version 1 (SYSV), not stripped
/usr/local/natinst/nikal/src/client/NiViPciK-processed.o_shipped: ELF 64-bit LSB relocatable, x86-64, version 1 (SYSV), not stripped
/usr/local/natinst/nikal/src/client/NiViPxiK-processed.o_shipped: ELF 64-bit LSB relocatable, x86-64, version 1 (SYSV), not stripped
Philippe BdA
Message 11 of 12
(559 Views)
I´m also trying to install in the SL6 and got exactlly the same problem:
# ./updateNIDrivers
Configuring for linux kernel version 2.6.32-220.13.1.el6.x86_64.
********************************* NOTE *********************************
Using kernel headers found in /lib/modules/2.6.32-220.13.1.el6.x86_64/source.
If this does not correspond to the location of the 2.6.32-220.13.1.el6.x86_64 headers,
then define KERNELHEADERS in your environment to point to the location
of the kernel headers, define KERNELTARGET as the version of the
kernel for which to compile, and then rerun ./configure.
Kernel has reparent_to_init(): no
Number of arguments for do_munmap(): 3
pte_offset function: pte_offset_kernel()
Levels in page table: 4
Kernel has remap_pfn_range: yes
Kernel has kzalloc: yes
Kernel has chained SGL support: yes
USB altsetting name: cur_altsetting
Kernel has usb_get_intf(): yes
Kernel has intf_cache member in usb_host_config: yes
Kernel has ep[] members in usb_device: yes
Kernel exports usb_set_configuration(): no
Units of USB_CTRL_GET_TIMEOUT: msec
Kernel has owner member in usb_driver: no
Kernel has put_page_testzero(): yes
Kernel has mutex method: yes
Kernel has wait_for_completion_interruptible: yes
Kernel has config.h: no
Kernel has ioctl32.h: no
IRQ handlers have pt_regs: no
Kernel has work_struct and delayed_work: yes
Kernel supports fault method in vm_operations_struct: yes
Storing configuration in Makefile.in
If the values stored are incorrect they can be changed before running make.
Installing NI-KAL:
NI-KAL successfully updated.
Updating client modules:
nipalk.ko successfully updated.
  CC   /usr/local/natinst/nikal/src/client/niorbk-interface.o
  SHIPPED /usr/local/natinst/nikal/src/client/niorbk-processed.o
  LD   /usr/local/natinst/nikal/src/client/niorbk.o
ld: Relocatable linking with relocations from format elf32-i386 (/usr/local/natinst/nikal/src/client/niorbk-processed.o) to format elf64-x86-64 (/usr/local/natinst/nikal/src/client/niorbk.o) is not supported
make[2]: *** [/usr/local/natinst/nikal/src/client/niorbk.o] Error 1
make[1]: *** [_module_/usr/local/natinst/nikal/src/client] Error 2
make: *** [all] Error 2
ERROR: failed to build niorbk.ko
niorbk.ko failed to update.
  CC   /usr/local/natinst/nikal/src/client/nidimk-interface.o
  SHIPPED /usr/local/natinst/nikal/src/client/nidimk-processed.o
  LD   /usr/local/natinst/nikal/src/client/nidimk.o
ld: Relocatable linking with relocations from format elf32-i386 (/usr/local/natinst/nikal/src/client/nidimk-processed.o) to format elf64-x86-64 (/usr/local/natinst/nikal/src/client/nidimk.o) is not supported
make[2]: *** [/usr/local/natinst/nikal/src/client/nidimk.o] Error 1
ERROR: failed to build nidimk.ko
nidimk.ko failed to update.
NiViPxiK.ko successfully updated.
make[2]: *** [/usr/local/natinst/nikal/src/client/nipxirmk.o] Error 1
NiViPciK.ko successfully updated.
Update of National Instruments drivers failed.
I saw in the internet that one could make an option "-m32" or "-m  elf32-i386" during the linking processes by a command like this:
export LDEMULATION=elf32-i386
but it didn't work.
Adriano
Message 12 of 12
(559 Views)
