Linux Users
Help Please
HELP
I try to install NI-DAQmx 8.0.1  But I have this message :
******************************** ERROR ****************************************
* The version of gcc in the path does not match the version of gcc used to *
* compile the currently running kernel. This can cause unpredictable *
* behavior in kernel drivers and should be fixed. *
* gcc version: version gcc 4.2.2 20071128 (prerelease) (4.2.2%3.1mdv2008.0)
* kernel compiled with: 4.2.2 *
what can I do please ?
And how can I make Utility ?
My mandriva is :
[root@localhost DAQ]# cat /proc/version
Linux version 2.6.23 0.rc8.rt1.2mdvsmp (mandrake@n5.mandriva.com) (gcc version 4
.2.2 20070909 (prerelease) (4.2.2 0.RC.1mdv2008.0)) #1 SMP PREEMPT RT Thu Sep 27
and my GCC version is :
[root@localhost DAQ]# gcc  v
Utilisation des specs internes.
Target: i586 mandriva linux gnu
Configuré avec: ../configure   prefix=/usr   libexecdir=/usr/lib   with slibdir=
/lib   mandir=/usr/share/man   infodir=/usr/share/info   enable checking=release
  enable languages=c,c++,ada,fortran,objc,obj c++,java   host=i586 mandriva lin
ux gnu   with cpu=generic   with system zlib   enable threads=posix   enable sha
red   enable long long   enable __cxa_atexit   disable libunwind exceptions   en
able clocale=gnu   enable java awt=gtk   with java home=/usr/lib/jvm/java 1.4.2
gcj 1.4.2.0/jre   enable gtk cairo   disable libjava multilib   enable ssp   dis
able libssp
Modèle de thread: posix
version gcc 4.2.2 20070909 (prerelease) (4.2.2 0.RC.1mdv2008.0)
Thanks you for your answer
(6,871 Views)
Please see the already started discussion on the NI forums.
Use NI products on Linux? Come join the NI Linux Users Community
(4,156 Views)
