Linux Users
GPIB-USB-HS, ni-4882.-2.9.0f0
Help me
I want to use GPIB-USB-HS, ni488.2-2.9.0f0, on Linux.
but, gpibexplorer cannot find,  GPIB-USB-HS Device.
  ScientificLinux 5.6 - OK(found), GPIB Communitaion Ok.
  ScientificLinux 6.1 - NG, cannot find.
  openSuse11.3      - NG, cannot find.
What's different? ScientificLinux5.6 vs ScientificLinux6.1 and openSuse11.3 .
Kernel Version?
ScientificLinux5.6 Kernel version is 2.6.18
ScientificLinux6.1 Kernel version is 2.6.32
openSuse Kernel version is 2.6.34
refer, README.
> Supported GPIB Interfaces
> PCI-GPIB
> PCI-GPIB/LP
> NI PCIe-GPIB
> PCI-8212
> PCI-8232
> PXI-GPIB
> PXI-8212
> PXI-8232
> GPIB-USB-B (Up to kernel version 2.6.24)
> GPIB-USB-HS (Up to kernel version 2.6.24)  <----- Down to ?
> GPIB-ENET/100
> GPIB-ENET/1000 (new)
(11,919 Views)
The GPIB-USB-HS won't work newer kernels
No, up to. With kerneles newer than that version it won't work.
(8,370 Views)
Why not?
(8,370 Views)
USB kernel API was marked as EXPORT_SYMBOL_GPL sometime back, and since our modules are not GPL, we can't link to them
This has come up again and again in other threads, for example: https://decibel.ni.com/content/message/24682#24682
Sorry, we can't do anything about that.
(8,370 Views)
I managed to get it working on CentOS 6.4 using a "license hack". That should be ok as long as you don't distribute it. Also you need to change around line 4085 in nikal.c:
-   snprintf(device->nameString, sizeof(device->nameString), "%s", usb_dev->dev.bus_id);
+   snprintf(device->nameString, sizeof(device->nameString), "%s", usb_dev->dev.bus->name);
That's all.
I wonder why NI cannot use libusb...
(8,370 Views)
We can use libusb, but changing the device access from kernel mode up to user mode while not breaking our software requirements is non-trivial and has lots of challenges (architecture-wise, performance-wise, multi-process-wise, etc).. Sorry .. We are looking into it, but no promises if/when it will happen.
(8,370 Views)
Just publish the kernel driver source under GPL, and you can use the usb framework again.
Proprietary kernel modules are insane anyways.
Linux Embedded / Kernel Hacker / BSP / Driver development / Systems engineering
(8,104 Views)
