Linux Users
Error 1 occurred at System Exec while building Shared Object
No, but I would be happy to follow your steps to try to recreate the problem here if that's any help.
Message 11 of 20
(1,066 Views)
Jeff2,
If you have a desire to see a 64-bit LabVIEW for Linux, please let your local sales person know. More voices are always better in these situations.
Randy Hoskin
Message 12 of 20
(1,063 Views)
Thank you for your help Jeff.Are you using LabView Linux 2009?
I am attaching AdditionSO.vi which I would like to create into a shared object.The following are the steps I am using to create one. I have also attached them in a file, for easier reference. These should be sufficient, however a more detailed steps are present in LV Help -> Index-> Application Builder-> Building Shared Libraries.
1. Create new Project and put AdditionSO.vi into it.
2. Right click on Build Specifications -> New-> Shared Object
3 Information-> Enter Build Specification name(say, MySharedLibrary), Target filename (libAdd.so), Destination Directory (where you would want to save the shared object)
4. Source Files -> Add the AdditionSo.vi  into Exported VI. The function Prototype would look something like: int32_t AdditionSO(int32_t input1, int32_t input2)
5. Preview -> Generate Preview -> OK
6. Expand Build Specifications so that you see the 'MySharedLibrary' entered in step 3 under  Build Specifications.
7. Right Click MySharedLibrary -> Build.
I always get this message:
"Error 1 occurred at System Exec: /usr/local/lib/liblvrt.so.9.0: could not read symbols: File in wrong format collect2: ld returned 1 exit status"
-H.
Message 13 of 20
(1,066 Views)
Let me outline the step I took to ensure they are the same.  A few options seem to be different.
1. Created new project.
2. Right clicked on "My Computer" and added AdditionSO.vi
3. Right clicked on "Build Specification" -> New -> Source Distribution
Step three is different than you listed.  This is the only option.  I don't see Shared Object, however I continue from this point
4. Enter info as you detail in step 3
5. Under source file click the -> arrow to add AdditionSO.vi to be included under "Always Included"
This is a little different then outlined in your step 4.  In addition I don't see anythin like int32_t AdditionSO(int32_t input1, int32_t input2)
6.  Finish you steps 5-7 and everything builds fine.  Under my build directory I see AdditionSO.vi.
This doesn't seem correct.  Am I missing something or looking in the wrong place?  I am using Labview 2009.
Jeff
Message 14 of 20
(1,066 Views)
A source distribution is not the same as a shared library build. Maybe you don't have application builder installed.
Message 15 of 20
(1,063 Views)
Hello Jeff,
Thank you for your help.
When I right click on Build Specifications, I get four options : 1. Application 2. Shared Library 3. Source Distribution 4. Zip File.
I am using LV Linux 2009 Professional version. Yours could be another version.
Hita.
Message 16 of 20
(1,063 Views)
I filed a bug report suggesting that we make this change. I also suggested that we look at the GCC environment variable so that the user can override the compiler. I don't know when this change will be made, though. For now you can use the trick Shawn suggested.
Message 17 of 20
(1,063 Views)
Your right, I have the Full Development System, not Professional.  I didn't even think about this because we have always had the Professional version.  I took at look at out past discs and it looks like we changed to Full for 2009 and I didn't catch it.
I'll probably look into this and if we have the Professional version I'll reinstall otherwise sorry I can't help.
Jeff
Message 18 of 20
(1,063 Views)
Hello Adam,
I am also getting an error when I try to upload a Shared object into a Vi using the 'Call Library Function Node'
-H.
Message 19 of 20
(1,063 Views)
You'll have to be more specific than that. Is your .so a 32-bit binary or a 64-bit binary? You can only use 32-bit binaries with a 32-bit LabVIEW (there is no 64-bit LabVIEW for Linux right now).
Message 20 of 20
(1,063 Views)
