Linux Users
Does the Linux software base support Simulated Devices?
I've only ever used National Instruments products through the DAQmx Base drivers via C programs so I'm not sure what capabilities I may or may not have on Linux.
I saw today that DAQmx 7.4 and later supports "Simulated Devices" that allow one to make calls into the NI driver without having those devices physically present.
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA03q000000x0PxCAI&l=en-US#toc2
I'd love something like this in order to benchmark my Linux code on a variety of platforms- is it possible to use Simulated Devices on Linux?
(4,089 Views)
I hope you're aware that only a few specific distros - in pretty old versions - are supported. Proprietary drivers just don't work reliably on GNU/Linux.
Linux Embedded / Kernel Hacker / BSP / Driver development / Systems engineering
(4,075 Views)
Hi metux,
I'm not sure what you're suggesting. Is there another C API other than DAQmx Base?
For what it's worth, I've never had serious problems with the DAQmx Base driver other than critically bad documentation.
(4,071 Views)
The right solution would be writing proper IIO drivers. But as long as NI is keeping the necessary specs a state secret, it will require a lot of reverse engineering work.
Just buying hw from a more professional vendor like is much cheaper.
I've once evaluated the crios for some clients. Conclusion: unusable for us.
Maybe you're fine w/ some specific, old, unsupported distro and kernel.
Maybe you're fine w/ a broken cpu architecture called x86.
Maybe you're fine w/ a ugly proprietary API, instead of IIO.
--mtx
(4,067 Views)
