Linux Users
DaqMx Configuration
New to Linux (CentOS) & LabVIEW and a specific question about the mxbaseconfig.
I succeeded in installing LabVIEW 2018, NI-Visa, Daqmx on CentOS 7 following instructions found here, here
All vi's are (at first glance) useable but since I come from a windows background and are used to MAX configurations I'm looking into using the mxbaseconfig tool as described here
I know I won't have the same functionalities as the MAX but it would be a good start.
I cannot find this tool in the Tools menu or on the Command Line (method 2 & 3 described in the link above)
Do I need to install something extra or make some configuration changes?
gr
Johan
(3,539 Views)
@Johan_De_PontieuI'm looking into using the mxbaseconfig tool as described here
That tool is used if you are using NI-DAQmx Base.  You are using full-fledged NI-DAQmx, so you should use the tools described here instead.
(3,504 Views)
OK, thanks I'll look into that
(3,474 Views)
