Linux Users
Announcing: Linux Device Drivers 2023 Q1 and LabVIEW 2023 Q1
Linux Device Drivers 2023 Q1 and LabVIEW 2023 Q1 are now available!
Linux Device Drivers 2023 Q1 New Features
  • Red Hat Enterprise Linux 9 support for NI-DMM, NI-FGEN, FlexRIO, NI-SCOPE, NI-SWITCH, and NI-Sync
  • openSUSE Leap 15.3 and openSUSE Leap 15.4 support for NI-DMM, NI-FGEN, FlexRIO, NI-SCOPE, and NI-SWITCH
  • Ubuntu LTS 22.04 support for NI-DCPower, NI-DMM, NI-FGEN, FlexRIO, NI-SCOPE, and NI-SWITCH
  • LV Host Interface API for FlexRIO, R Series, cRIO, and RIO
  • For details refer to the NI Linux Device Driver readme
  • For the complete list of operating system support, refer to the NI Hardware and Software Operating System Compatibility webpage
New Features for LabVIEW 2023 Q1
(3,828 Views)
Failed on ubuntu 22.04.1 virtual machine
Device: USB-6525
followed instructions in: (https://www.ni.com/fi-fi/support/documentation/supplemental/18/downloading-and-installing-ni-driver-software-on-linux-desktop.html)
Following commands run manually, fails on latest "apt-get update" step:
apt-get update
apt-get upgrade
apt-get dist-upgrade
unzip ./Downloads/NILinux2023Q1DeviceDrivers.zip
dpkg -i ./Downloads/NILinux2023Q1DeviceDrivers/ni-ubuntu2204-drivers-2023Q1.deb
apt-get update
apt-get -y install ni-hwcfg-utility
dkms autoinstall
And re-trying the apt-get update gives following output:
Hit:1 http://fi.archive.ubuntu.com/ubuntu jammy InRelease
Hit:2 http://fi.archive.ubuntu.com/ubuntu jammy-updates InRelease
Hit:3 http://fi.archive.ubuntu.com/ubuntu jammy-backports InRelease
Hit:4 http://security.ubuntu.com/ubuntu jammy-security InRelease
Hit:5 https://download.docker.com/linux/ubuntu jammy InRelease
Hit:6 https://download.ni.com/ni-linux-desktop/2023/Q1/deb/ni/focal focal InRelease
Hit:7 https://download.ni.com/ni-linux-desktop/2023/Q1/deb/ni/jammy jammy InRelease
Get:8 https://download.ni.com/ni-linux-desktop/stream/deb/ni/jammy jammy InRelease [3,064 B]
Get:9 https://download.ni.com/ni-linux-desktop/stream/deb/ni/jammy jammy/ni i386 Packages [27.5 kB]
Err:9 https://download.ni.com/ni-linux-desktop/stream/deb/ni/jammy jammy/ni i386 Packages
  File has unexpected size (27469 != 27547). Mirror sync in progress? [IP: 104.18.198.58 443]
  Hashes of expected file:
   - Filesize:27547 [weak]
   - SHA256:8238a5af52a230450fc12d0a54ba24911eb6b20cca9b9d2f4959e95918a5c37b
   - SHA1:b4922855d64e2c93f7154933d7997a170b16b314 [weak]
   - MD5Sum:c5071add845f97a7ab33caf55712003f [weak]
  Release file created at: Fri, 27 Jan 2023 21:02:20 +0000
Get:10 https://download.ni.com/ni-linux-desktop/stream/deb/ni/jammy jammy/ni amd64 Packages [85.1 kB]
Err:10 https://download.ni.com/ni-linux-desktop/stream/deb/ni/jammy jammy/ni amd64 Packages
Reading package lists...
second apt-get update gives different file size comparing errors (85299 != 85114) and it seems that these two are altering every second time.
NI device is connected and recocnized in usb port. lsusb provides following output:
Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 001 Device 005: ID 3923:71df National Instruments Corp. NI USB-6525
Bus 001 Device 004: ID 04d8:00de Microchip Technology, Inc. MCP2210 USB to SPI Master
Bus 001 Device 003: ID 04d8:00de Microchip Technology, Inc. MCP2210 USB to SPI Master
Bus 001 Device 002: ID 80ee:0021 VirtualBox USB Tablet
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
So the device is located in: /dev/bus/usb/001/005
(3,582 Views)
Got rid of that apt update issue by creating a clean installation of ubuntu and using only "apt" and no "apt-get" in any place.
Still some issues persist when using nidaqmx python library, added my comment to topic previously opened on this matter:
https://forums.ni.com/t5/Digital-I-O/install-NI-DAQmx-driver-in-Linux-device/m-p/4301217#M24671
If someone knows what is wrong with this some hints would be appreciated.
I think this has something to do how the host links the usb device to the driver.
(3,576 Views)
Unfortunately the USB-6525 is not supported on any Linux OS's
From: NI Hardware and Software Operating System Compatibility
(3,568 Views)
