LabWindows/CVI
writing oscilloscope waveform data to a file using labwindows/CVI 7.0
I am trying to write waveform data (ViReal64*) from my oscilloscope to a file. I know how to use the ArrayToFile() method, but that will not work for this type of data. Any ideas?
(3,326 Views)
Is there a particular format that you would like to use to write your data to file? If so, you may have to do a little bit of type casting. I believe the data type ViReal64 is a typedef of the native data type double. I think if you treat it as a double, you can write the data to file without a problem. If this doesn't work for you, can you post an example of the data you're getting? You should be able to see what the data is by setting a breakpoint in the program and then looking at the variables.
Jeremy L.
(3,306 Views)
Ah... mental error, I was trying to write an array of pointers to ViReal64 objects rather than an array of just ViReal64 objects (which are in fact treated as doubles) thanks for the help.
(3,282 Views)
