LabWindows/CVI
write number in a txt file
I have a VI, she give me as result 2 number, I want to stor these numbers in two different texte file.
I found no fuction to do that.
thank you for your help
(3,777 Views)
simply use the standard ansi c functions.
fopen()  to open a file
fwrite() and fread() to access the data which are in the file you opened
fclose() to close the acces to the file
Regards
     NI_Device_user
(3,769 Views)
I dont want to use C laguage I only need to make it with VI
thanks
(3,766 Views)
(3,763 Views)
You should post that question to the LabVIEW forums instead of the LabWindows/CVI forums.
NickB
(3,750 Views)
You could use WriteToTextFile.vi properly formatting your data into a string: see the example Write To Text File.vi (formatting will depend on wether your data are an array of measures or a single value).
To format your numbers you could use Build Text express vi or some vi from the String/Number Conversion palette.
(3,728 Views)
