LabWindows/CVI
write in a text file
Hallo everybody,
I have to write in unregular disctances one text line with a timestamp in a text file, so I get an Logfile.
Is there an example or something else?
Can anybody give me perhaps some example functions which I will probably need!
Florian
Message 1 of 44
(12,047 Views)
 fH = OpenFile ("logfile.txt", VAL_WRITE_ONLY, VAL_APPEND, VAL_ASCII);
 sprintf (msg, "%s [%s]: Your line of data", DateStr (), TimeStr ());
 WriteLine (fH, msg, -1);
 CloseFile (fH);
Message 2 of 44
(12,035 Views)
Thanks a lot again Roberto!
Florian
Message 3 of 44
(12,038 Views)
hi Roberto, this might seem silly...but how do you declare msg?
i tried somethign like
char *msg
char report [MAX_PATHNAME_LENGTH]
fH=openfile( report,VAL_WRITE_ONLY,VAL_APPEND,VAL_ASCII);
msg = &report ;
writeline(fH,msg,-1);
it gave me errors after this...am i doing something wrong?
Message 4 of 44
(11,813 Views)
declare msg at a fixed length - just make sure it is long enough.  ( char msg[256]  or 128 or 100).
Also, the first param to openfile should be the file's name (and directory path if needed).
for example:
fH=openfile( "c:\Reports\Debug.txt", VAL_WRITE_ONLY,VAL_APPEND,VAL_ASCII);
You are not giving it a name at all in your statement.  You have only dimension-ed an array when you define 'report'.
Message 5 of 44
(11,809 Views)
hi,
i tried what you told me...but it doesn't seem to be working...i want to write some text to the file and i want the format to be like this
NAme
Date, Time, etc...
how do i enter the text into the file? should i just do something like this...
char msg[MAX_PATHNAME_LEN]="Name";
char msg1[MAX_PATHNAME_LEN]="Date, Time ";
fH = OpenFile ("C:\\path\\file.csv", VAL_WRITE_ONLY, VAL_APPEND, VAL_ASCII);
WriteLine (fH,msg,-1);
WriteLine (fH,msg1,-1);
is there a better way to write this?
would appreciate a reply
thanks..
Message 6 of 44
(11,807 Views)
hi...i sorta solved the problem by using sprintf ...so it kinda worked...
thanks..
Message 7 of 44
(11,806 Views)
the thing that i do want is for the user to be able to select the filename ...i want to generate a new text file on every write...so i need to change that variable...that's why i declared
char report[MAX_PATH_LENGTH]
and then tried a strcpy of the path...but can you suggest a better approach in terms of the syntax?
Message 8 of 44
(11,806 Views)
Here is a way I have done it in the past.  Note that this keeps 20 copies (you can change it to keep more) of a file names Debug_Out01.dat, Debug_Out02.dat    through   Debug_Out19.dat, and Debug_Out20.dat.
It creates these files in a directory called "Debug" within the directory from which it is run.
The "File*  Debug_File"  is defined globally.  Anything else not defined locally to this routine was also defined globally.
A routine to return a pointer to the file was written so that multiple codes in multiple files could all call the same debug file.
Message Edited by scomack on 02-13-2007 02:38 PM
Message 9 of 44
(11,794 Views)
Hi nadster,
it's not clear to me what's your intention, but I can give you two suggestion: I hope one at least can help you a little...
If you want the user to be able to select its own file you can use FileSelectPopup, a function that opens standard "Open file..." dialogue box permitting the user to navigate up to the directory he wants and to select an existing file or type a new filename for the file to be created.
On the other hand, if you want to programmatically and progressively increase a file count you could rely on CreateAndOpenTemporaryFile, that permits you to input prefix and extension for a given file, automatically creating and opening a new file with the name "prefixNNN.ext" where NNN is a index for the file immediately available in the series. With this command you can automatically create up to 1000 files with a given prefix+extension pattern. The function automatically checks for duplicates and creates a surely unique filename (it returns -91 too many files on the 1001st filename).
Message 10 of 44
(11,782 Views)
