LabWindows/CVI
windows sdk help file?
Hi !
I'm looking for windows sdk help file ?
I'm using LabWindows 5.5 and I can't find
information about windows sdk functions ?
Piotr
(3,259 Views)
In order to use Windows SDK files you must have CVI Full Development System, not the starter kit nor base package.
To install SDK on your hard disk you must run Custom installation: you will be prompted for a list of all installable items in which to select the appropriate options.
Hope this helps
Roberto
(3,259 Views)
Thank you !
(3,259 Views)
