LabWindows/CVI
windows 8 text
Built my LabWindows 2012 application and tried to install in a WIndows 8 computer. Everything fine, except that certain text appears quite different than under Windows 7. Not sure how to fix this. Anyone else run into this problem? How to fix ? Thanks.
(4,956 Views)
I haven't run into this, but if you could post a screenshot, that might help us see what you're seeing.
Also, where is this text?  Is it the label for a control or the text inside an indicator, etc.?
-Jim B
Applications Engineer, National Instruments
CLD, CTD
(4,928 Views)
Everything is fine, that was my mistake. A client's laptop had the font setting at 125% instead of 100%, and I did not catch that right away
Thank you.
(4,822 Views)
