LabWindows/CVI
windows 7
I am trying to launch a CVI app under Windows 7 in debug mode and I get an error: "The application was unable to start correctly (0xc000003b). Click OK to close the application". I used to launch it OK under windows XP. Any idea what the problem can be?
(4,178 Views)
Persemeng,
Its hard to say what could cause a nondescript error like this without more context to the program to the machine. Have you tried this on multiple Win7 machines with the same behavior? have you distributed it with the CVI RTE? Have you distributed other programs to win7 machines before successfully, or is it a problem with all distributions to win7 machines? Did you run the install of the RTE and drivers as an administrator on the Win7 machine?
If you can include the program, or another simple example that also produces the behavior, it will be much easier to trakc down the source of the issue.
Kyle Mozdzyn
Applications Engineering
Kyle M.
(4,159 Views)
Im getting this error as well.  I have tried multiple win7 machines and have tried CVIRTE's 10.0.1.419 and 10.0.1.434  It has worked on a co-workers machine and i tried to configure a win7 pc the same way but still get the error.  any ideas?
(3,510 Views)
