LabWindows/CVI
visual basic and cvi
I have to use Labwindows/CVI in order to do an automatic test bench.The component tested is controlled by an other software in Visual Basic. How can I control the Visual Basic software with Labwindows. Maybe with dll from VisualBasic but I don't know how to do. Please, help! Thanks in advance. Arnaud2404
(3,129 Views)
Hi Arnaud,
If you need to call VB functions from a LabWindows/CVI application to control the tested devices then you need to create a VB DLL that you will call from LabWindows/CVI. As VB DLLs expose their functions in a particular way, you can't call them directly from LabWindows/CVI and you will need to create an ActiveX controller.
To have more infomations about it :
http://digital.ni.com/public.nsf/websearch/AA35D259FD350D3E8625699F0059C641?OpenDocument
Benjamin
Application Engineer
National Instruments France
(3,129 Views)
