LabWindows/CVI
visa32
I have "visaLocalTmo could not be located in the dynamic link library NIVISV32" message. I had used agilent IOLibSuite15 before and had error on serial connection. So, I decided to reinstall VISA entirely after this following message appaired:
":\WINNT\system32\visa32.dll was found but could not be loaded.
MAX has detected that NI-VISA is installed on your system, but visa32.dll could not be loaded.  One or more files that visa32.dll depends on may be missing.
Try reinstalling NI-VISA by closing MAX and selecting your NI-VISA installation in Add/Remove Programs in the Control Panel.  Follow the steps in the installation dialog to repair
your installation.  Re-launch MAX, and refresh the configuration tree to view your devices.
Possible causes for this error:
1. NI-VISA was not properly installed on your system.
2. NI-VISA was not properly uninstalled from your system.
3. A file or component that visa32.dll depends on may have been moved to another location on your hard drive.
 Which then brought me back to the current issue.
Thanks for any help,
BSA
(5,256 Views)
If you want to finally use NI-VISA, do thw following:
1) Uninstall both NI-VISA and Agilent IO Libs.
2) Confirm that VISA32.DLL is removed from Windows/System directory.  If not deleted, delete VISA32.DLL by hand.
3) Reinstall NI-VISA.
4) See the VISA32.DLL's property by Windows Explorer and check if the DLL is from NI.
(5,210 Views)
Hi Makoto,
That works thanks. Now I have another issue with VISA alias vs. COM port number assigned by window and MAX doesn't  seem to work.
Aziz.
(5,184 Views)
Hi BSA,
Could you talk a bit more about what you mean by MAX does not seem to work? Does MAX crash?
Let us know!
Rasheel
(5,162 Views)
Hello Sputnikre,
Here is the message went trying to config to COM3 :
The alias "COM3" is already bound to resource "ASRL18::INSTR". I don't have 18 (or at least it doesn't show in the MAX list).
(5,154 Views)
Hi BSA,
At what point does this happen? Do you see this message when you start MAX up? Or when you are assigning aliases?
Rasheel
(5,132 Views)
This happen when assigning alias. I got NI support help. I had to remove the card and start MAX to clear all aliases. Put back the PCI-232/8 then everything went back to normal. That was a tidious exercise.Smiley Mad
(5,125 Views)
