LabWindows/CVI
viFindRsrc using VI_ATTR_USB_SERIAL_NUM
I'm trying to get the VISA resource string for a USB/RAW device based on the serial number.  If I do
viFindRsrc(hRM, "/USB?*RAW{VI_ATTR_USB_SERIAL_NUM == 123456/789}", VI_NULL, &lCount, szBuffer);
I get VI_ERROR_RSRC_NFOUND.  However, if I just use "/USB?*RAW" as the resource string, then go through the list, open a session to each device, and use
viGetAttribute(hSession, VI_ATTR_USB_SERIAL_NUM, szBuffer);
I can find the correct device by looking at szBuffer.  Am I doing something wrong in the viFindRsrc call?  Do I need to escape the / in the serial number, for instance?  Or is going through the full list the only way to find the device?
Thanks in advance for your help.
(5,946 Views)
Hi Tevildo,
It may be worth having at look at this KnowledgeBase article: How do I Find All VISA Instrument Resources Using LabWindows/CVI?
I hope this helps!
SFuller
(5,909 Views)
Thanks - that's what I'm doing at the moment - I was wondering if it was possible just to use one call to viFindRsrc, rather than having to iterate through the entire list of instruments.
(5,907 Views)
Accepted by topic author Tevildo
From what I've found so far, going through the full list is the only way to find the device.
(5,882 Views)
