LabWindows/CVI
vertical text orientation
I need to vertically orient a text box in my CVi GUI.  This is easy to do in LabView.  How can I do it in LabWindows?
Josh
Message 1 of 11
(5,313 Views)
jmoses,
I don't know if there is a way to do it using CVI, but there is a way to programatically do it.  See the code sample below:
 char Str1[10] = "HELLO";
 char Str2[10] = "WORLD";
char temp_Str[4] = ""
for (index = 0; index < 6; index ++)
    temp_Str[0] = Str1[index];
    temp_Str[1] = 32;                    //ASCII space character
    temp_Str[2] = Str2[index];
    InsertTextBoxLine (panel, PANEL_TEXTBOX, index, temp_Str);
P.S. please excuse my other posts, I hit the TAB key and then SPACE BAR really quickly causing my message to be posted a bunch of times
Message Edited by DaveC on 07-12-2005 02:53 PM
Message 2 of 11
(5,310 Views)
Duplicate post by accident
Message 3 of 11
(5,309 Views)
Message 4 of 11
(5,199 Views)
DaveC,
Thank you, this is interesting, but I would prefer to have the letters oriented 90 degrees, like on the spine of a book, or the Y-axis label of a graph.
Josh
Message 5 of 11
(5,301 Views)
Hello JMoses,
You can generate vertical text with a text massage control by putting new line characters between each letter in the message.  On the UIR, you should place the text message control on top of your graph where you want the Y-Axis label to be.  Then you can change the Z-Order so the text message appears on top of the graph (Arrange >> Control ZPlane Order).  Then when you edit the value of the text message, press <CTRL-Enter> between each letter to create vertical text.
Likewise, you can print vertical text programmatically by doing something like: SetCtrlVal (panelHandle, PANEL_TEXTMSG, "T\nE\nS\nT\nI\nN\nG")
Thanks.
Wendy L
LabWindows/CVI Developer Newsletter
Message 6 of 11
(5,293 Views)
Dear Wendy L,
Thanks.  Your suggestion is similar to DaveC's suggestion.  But apparantly I have not been clear about what I need.  I want the letters rotated 90 degrees.  So when you turn you head 90 degrees, you read the text normally.  Most books, including the NI catalog, have their titles printed on the spine in this way.  And CVI's built-in Y-axis graph label is printed this way.  I want to make my own labels like this.
Josh
Message 7 of 11
(5,290 Views)
Hello jmoses,
Got it.  Check out the following example program which demonstrates how to rotate text using the canvas control [link removed; example no longer available].
Thanks.
Wendy L
Message 8 of 11
(5,288 Views)
This will work.  Thank you very much.
If I had only used the keyword, "rotate," instead of "vertical orientation," in my search, I would have found the example myself.
Josh
Message 9 of 11
(5,281 Views)
Hello JMoses,
I did some further research and came across another way to do vertical labels.  Check out the following KnowledgeBase [link removed; article no longer available].
Thanks.
Wendy L
Message 10 of 11
(5,279 Views)
