LabWindows/CVI
vertical line on XY graph
I have a problem with plotting vertical lines on XY graph. I used "vertical bar" plot style and everything seems to be ok exept thickness of plotted lines: for some plots (at the same graph) they are thicker that for others. Inside one plot lines are the same. Plot thickness attribute doesn't change anything. I don't want to use PlotLine since I want to have one plot handle for lines from the whole array.
Any ideas where does the problem came from? Greetings
(3,487 Views)
Dear criceto,
what version of software are you using? Could you maybe post some exemplary program or screenshots?
(3,457 Views)
