LabWindows/CVI
valid path for execution
I am using CVI 2013 to run my program on a real time target and the CVI requires me to put a valid path for execution.
However, I only know the IP address of the RT target but it doesn't allow me to just simply put the IP address on the directory.
What should I put instead?
(3,881 Views)
Hi Trailblazer,
You should be able to ftp into the RT target and see the file structure. You can also create a folder on there.
http://www.ni.com/white-paper/14669/en
The white paper above may also help.
Best Regards,
Chris
National Instruments - Tech Support
(3,861 Views)
