LabWindows/CVI
using shared variable in CVI
Hi Charlie
The behaviour of DataSocket server is same no matter were the DS server is run, Am currently running the DS server on a Windows 2003 server machine. I found that the behaviour of DS server is same if I run it on my host machine with Windows XP prof.
Regards
Arun
Message 11 of 12
(1,272 Views)
Hi Arun,
I wonder at this point, if it isn't something inherent in your network topology that is causing this issue. You mentioned earlier that DS Server is slow to respond even with just one RT target. Perhaps there is still something different in your setup from mine....I have attached a very simple VI I'd like you to run on the RT targets in question. You'll have to change the hostname in the URL for the datasocket Vi's, but otherwise it's pretty straight forward. This will also take CVI out of the picture entirely, since all we care about is the behavior of the DS server.
As for the network, how do you have the IP's configured for the RT targets -- is it DHCP or a static IP address? Are you going through a router that is common to all four RT targets? Can you try using a crossover cable between the RT target and the machine running the DS Server?
Also, (just FYI), Windows Server 2003 is not officially supported with DS Server. I've only been trying this with XP Prof SP2.
Let me know what you find out!
Charlie S.
Visit ni.com/gettingstarted for step-by-step help in setting up your system
Message 12 of 12
(1,239 Views)
