LabWindows/CVI
using .cpp file to create dll
  I have some header files which seems to be written in c++. Can I make a .cpp file in VC++,include these header files, build a dll and call the dll from LV? I know that we can call dll written in C but I want to know whether it will work for .cpp files too.
Thanx & Regards,
Srini.
(3,169 Views)
You shouldn't have any problems building a dll in VC++ that can be used by any other language. You might need to prevent the C++ compiler from 'name mangling' the functions in the dll by adding: extern "C"  to their definition.
('Name mangling' is the process by which a C++ compiler generates unique internal identifiers for overloaded functions ie multiple functions in a single program which all have the same name but have different parameter lists and/or return types.)
JR
(3,164 Views)
